Re: Farmall h fuel adjustment screw
Posted by riverbend on April 22, 2012 at 17:24:38 from (74.46.176.37):
In Reply to: Farmall h fuel adjustment screw posted by chaneg78 on April 22, 2012 at 17:17:55:
Tighten the packing nut that is between the adjustment screw and the carb body until it quits dripping gas. If the nut is already tight, you need a new packing.
