There is probably some rust built up on the flywheel clutch surface from sitting so long.
At around 1/4 throttle hold the brakes hard and SLOWLY let out on the clutch pedal, when it begins to drag the rpms down STOP and push all the way down to release, do this two or three times & that should clean the rust off. Finally - re adjust the clutch & lube the pivot points per the operator's manual.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
