How do I remove the input yoke from the input gear shaft? The bolt is out and I've pried and hammered (lightly) but it hasn't moved that I can tell.
Looks like the seal retainer has 3 bolts and is bolted to the bearing cage which has 6 bolts. The yoke has to come off to remove the seal retainer, in which case I'm not sure the seal retainer has to come off at all. Or, do I need to remove the bearing cage & input shaft so the whole assembly is out where I can work on it?
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
