helper spring and generator question
Posted by johnald on April 24, 2012 at 09:59:16 from (74.240.136.6):
I noticed today that the bracket for the helper spring for the quick hitch on my 130 is pivoting around the bolt causing it to rub on the rear fender. I tried tightening it but it still moved and hit the fender. Is the bracket supposed to move? Doesn't seem like it will help lift anything if it does.
Also, I have been trying to get the generator to charge properly. I went through all the connections a while back and took them apart and cleaned them. I took the cover off the gen and oiled and air cleaned it. Now the generator is giving me the propper 7.5 volts at the gen but I only get about 6.3 at the battery. I checked the voltage regulator and get 7.5 at the gen terminal and 6.3 at the bat terminal. The ammeter shows a slight charge but the needle is eratic and wobbles back and forth. Bad vr? Bad ammeter?
thanks in advance for any help.
