Re: Super C not starting Update
Posted by mkirsch on April 25, 2012 at 05:45:10 from (64.80.110.74):
In Reply to: Super C not starting Update posted by I luv farmalls on April 21, 2012 at 19:02:03:
It could still be a voltage drop problem.
After you charged the battery, the voltage was high enough to turn the starter and charge the ignition coil.
As long as you run it often enough and long enough to keep the battery charged, it will continue to start. Leave it sit for a month and you may be in for a re-lapse.
For $20 you can purchase an automatic battery maintainer at TSC or Walmart. If you plan on leaving the tractor sit for a length of time, and it's near power, you would be wise to attach the maintainer and plug it in. This will keep the battery topped up and ready for the next time you want to run the tractor.
