Re: Timing a Farmall H Tractor
Posted by SadFarmall on April 26, 2012 at 05:51:02 from (112.213.163.145):
In Reply to: Timing a Farmall H Tractor posted by Picklesmith on April 26, 2012 at 05:03:58:
If you put your thumb over the spark plug hole and feel pressure, then you really only need to crank the motor until the timing point and notch are aligned unless you suspect the pulley has been fitted incorrectly.
SadFarmall
