It's a relatively straight-forward job. A few tips from my experience:
- An engine hoist, or a tractor with a front loader will make the rest of the job MUCH easier/safer.
- Jack the front end then support the tractor with timber cribbing or similar beneath the clutch housing so the front wheels are off the ground. Be sure to block the rear wheels both front and back, and set the brakes!
- Remove the lower bolster/wheel assembly. Note one of the 4 bolts (the right front) has an extended head. It sets the left/right steering stop. When reinstalling the front wheels this bolt must replaced in the same location with the pivot shaft in the "straight ahead" position.
- The pivot shaft gear is on a tapered spline. To remove take out the cotter pin then loosen the nut on top of the gear 2-3 turns. A few good licks from a large hammer/sledge should pop the gear and let the pivot shaft drop. Protect the nut with a scrap of soft metal while hammering. And remember the pivot shaft is HEAVY - watch your toes!
- The old bushings are best removed by splitting with a cold chisel then collapsing so they can be pulled out.
- New bushings should go in easily with a bit of light tapping. Be sure to align the lube hole in the lower bushing with the grease fitting on the fixed bolster. Or remove the grease fitting and drill through the bushing wall after it's in place.
- The shaft seal can be a stinker to install. I turned a "tool" from a wood dowel scrap to position and knock the seal into place.
- Even with a new seal the steering box is likely to have a slow oil leak on account of shaft wear in the seal area. Better idea is to pack the box solid with good quality grease - it'll lube the worm gears just fine and it won't leak past the seal.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
