Re: Super H restoration
Posted by neblinc on April 26, 2012 at 18:17:02 from (204.80.196.2):
In Reply to: Super H restoration posted by Joe in CA on April 26, 2012 at 17:52:09:
First off you need to see if it will run. Check the gas tank for rust or any other goo. The sediment bowl may be all gummed up also. The carb may need attention also. New plugs, check the cap, rotor & points for any rust,
drain engine oil and put in fresh oil & filter.
Once you get it running you can take care of the tranny fluid later.
Hope it fires right up for you.
Randy
