Re: Super H restoration
Posted by Super-H-Mike on April 26, 2012 at 18:34:12 from (76.164.145.223):
In Reply to: Super H restoration posted by Joe in CA on April 26, 2012 at 17:52:09:
Don t know about california, but here in Minnesota it would have water from condensation in the rear diff. The water will be settled to the bottom so pulling the drain plug and letting it run out til its only oil coming might be a good idea....
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
