Re: H w/ saginaw three point question
Posted by Zachary Hoyt on April 26, 2012 at 19:01:05 from (74.47.48.83):
In Reply to: Re: H w/ saginaw three point question posted by sgtbull on April 26, 2012 at 16:11:51:
Two things I have seen will take the detent and nib out of sync. One is if the bolt is loose that holds the short arm onto the side of the belly pump. The other is if the arm that the control rod is held up by is bent or loose.
Zach
