Re: H w/ saginaw three point question
Posted by Janicholson on April 26, 2012 at 21:32:25 from (67.72.98.45):
In Reply to: Re: H w/ saginaw three point question posted by sgtbull on April 26, 2012 at 16:11:51:
I agree, the nib is the middle position and is the hold location. Lift is pull out all the way (internal detent and it self releases if the system goes to bypass from full extension of cylinder.)
To lower it must be lifted above the nib and pushed in. If it is not holding in the mid position, and lowers even faster if pushed in just a little from Nib position, the linkage is not correct, or the rod is the wrong length.
On ours the rod must be pushed in at least 2 inches before it lowers at all. Jim
