Re: Super M Stages,Just a little confused here????
Posted by D Slater on April 27, 2012 at 04:59:54 from (184.15.29.13):
In Reply to: Re: Super M Stages,Just a little confused here???? posted by Mike1972chev on April 27, 2012 at 03:24:08:
third party image
Whatever you want to call them there was SM tractors of one type below the serial numbers I posted and one type above the serial numbers until they stopped being made. Ones above the serial numbers had chassis changes to accomadate a engine driven liftall attachment if used. If tractors serial numbers F28175 and L504802 were equiped with a transmission driven liftall attachment they still had the other chassis changes that the engine driven pump tractors.
Exept a rear fuel tank support was used in place of the reservoir with special bracket for the relocated control rods Also a seal, bearing retainer and drive dog nut added to the transmission counter shaft.
Serial numbers 60001 up are considered a SMTA chassis T/A or not.
Think the only reason IH changed the clutch housing for Stage 2 tractors was they finaly wised up and decided why are we making 2 different housings when one would do.
If a stage 1 tractor has a battery box under the seat it got this attachment (pic) purchased later or off another tractor or just the parts bought.
