Posted by old on April 27, 2012 at 08:56:14 from (209.86.226.27):
In Reply to: Re: stuck piston posted by longear on April 27, 2012 at 06:31:59:
If you can do so safely try this. Fill that cylinder 3/4 of the way full of ATF then add a couple tablespoons of gas to that. Let it sit a few minutes so as to mix it up then light it on fire. Add gas 2 or 3 times after it has stopped burning. Then try to remove that piston after the fluid has cooled to a safe temp. What that does is heats and expands that cylinder and sometimes that with the ATF seeping down the sides of the piston and ring will be enough to free it up. I have free up a few engines using that trick over the years
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You
... [Read Article]
Latest Ad:
[More Ads]
