Re: super H ?
Posted by Pat in Wis on April 27, 2012 at 09:23:11 from (66.87.0.203):
In Reply to: super H ? posted by Dennis Laper on April 24, 2012 at 18:59:27:
if you can get me the serial number of the motor block that is stamped into the raised "platform" below # 3 spark plug I should be able to figure your serial number out - at least very close. it might be a few days - trying to get corn planted - just not having much luck.
Pat H in Wis
