Posted by Janicholson on April 28, 2012 at 15:37:08 from (96.24.99.126):
In Reply to: 706 gas no start posted by John V. on April 28, 2012 at 14:09:56:
The first diagnosis step is to determine if it is getting spark. Pull the center wire out of the distributor cap, and place it (tape is handy) so that it is 1/4" away from the block. Crank the engine watching for spark. it should be bright and Blue, not yellow or thready. If no spark, check the condition of the contact points. They can be cleaned and polished with 320 grit paper, then cleaned with a folded dollar bill. Set them on the high point of the distributor cam at .020" Jim
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
