Posted by Janicholson on April 28, 2012 at 15:47:22 from (96.24.99.126):
In Reply to: surging A posted by charlie M on April 28, 2012 at 13:08:47:
Be sure that when the governor is set to wide open(tractor off) that the linkage from the governor cross tube arm and the carb link arm, The carb should be held just fully open in this position. The pivots and rod ends should be tight and without slop. They can be welded up and made tight. The tube from the governor can also have bad bushings in the end, If these are OK, and it still surges, there is a possible issue with the high speed mixture (helped if the float level is correct). The main bearing in the governor.can also be loose. Jim
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
