Re: 706 gas no start
Posted by El Toro on April 28, 2012 at 16:14:22 from (108.3.225.57):
In Reply to: 706 gas no start posted by John V. on April 28, 2012 at 14:09:56:
Hold your hand over the throat of the carburetor and while a helper make's an attempt to start the engine & see if there's good suction. Low suction means low intake manifold vacuum. I would look at the plugs to see if they're wet.
Check your ignition to make sure battery voltage is getting to your coil. Use a volt meter and with the points open you should see voltage on both small terminals. You also need the ignition in the on position when doing bthis. Hal
