Re: SH Gasket set Copper washers
Posted by CNKS on April 29, 2012 at 07:20:45 from (216.144.104.128):
In Reply to: SH Gasket set Copper washers posted by Va Gasman on April 29, 2012 at 05:45:13:
The oil pump gaskets give the proper clearance between the gears and the bottom cover. You need to put in the same number you took out, provided the cover is not worn too much, in which case you need to sand it flat or replace it.
