Re: brake clean up on H
Posted by Janicholson on April 29, 2012 at 07:32:16 from (96.24.99.126):
In Reply to: brake clean up on H posted by Bill Bowen on April 29, 2012 at 06:58:55:
Rusty is correct. Pulling the old seals out, and cleaning the shaft to metal to be able to see it clearly, is needed. Using a good bright light, see if there are grooves in the pinion shaft. a probe like a dental pick, or wire can be used to "feel" for grooves. A hand lense can also help (I use one to see well close like this (63yrs old)) Grooves allow even new seals to leak. placing the new seal at a depth where there is no groove works. Pack the new seal with grease, and grease the shaft when putting it in. This assures it will have a long life.
Jim
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
