Carbs do not suck fuel from the line, so the first issue is finding if it is getting sufficient fuel. Remove the fitting at the carb, use a clean pan and test the flow by turning on the valve at the sediment bowl. If a soda straw size stream flows it is good. if not clean the supply. if good, the carb is not flowing fuel internally. If you purchased a rebuilt carb, I would send it back. If you did it, purchase a can of carb clean that is big enough to submerge the carb parts. leave for two days. then use fine wires and air to blow out each and every passage. Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
