Re: chaining down your Farmall?? Your thoughts please.
Posted by Old-F20 on April 29, 2012 at 08:28:20 from (71.7.101.5):
In Reply to: chaining down your Farmall?? Your thoughts please. posted by colby64 on April 28, 2012 at 18:02:45:
IIRC here in iowa if an item has a weight of 5000lbs or more, you have to put 4 chains with 4 points of pull on it. do we all do that on tractors? not really, but as Rustyfarmall pointed out you will get looked at and its all dependant on what kind of day the DOT guy is having whether or not you get to receive a driving award.
on a 560 best thing to do is permantly mount 2 hooks at the front of the framerails to put a chain off each corner. the bolster and framerails are a lot stronger that the front wheel pedistal should you get in a wreck of somesort.
