Posted by Dachshund on April 29, 2012 at 08:35:37 from (98.16.178.155):
In Reply to: Re: OEM bolts posted by CNKS on April 29, 2012 at 07:30:30:
Way back when - when I worked at a Materials & Research Lab - we tested a LOT of different fasteners. Split Lock washers as a whole only worked a VERY small percentage of the time - and only when torqued PROPERLY. Once used, they failed EVERY time to function properly when re-installed. The whole system is based on something that only "works" when the bolt is already loose. They are a good "spacer", but not much more..... I still use them - even though I know they don't really work, but they LOOK right on old tractors. The problem with reusing them is - they get work hardened and brittle, then break CAUSING the bolt to loosen.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
