Re: Super M Differential Removal
Posted by pete 23 on April 29, 2012 at 16:47:03 from (74.32.231.176):
In Reply to: Super M Differential Removal posted by dpoc on April 29, 2012 at 15:14:14:
Some of the manuals don't really give you a step by step procedure for disassembly. Just pull the top cover off. Put stands under each axle housing, then take wheels off, push axles out after taking bolt out of end of axle,(use original or longer bolt and block between axles and hold bolt, turn axle) take bull gears out, brakes off, bull pinion shafts out. Then support the differential and take diff support off both sides. Keep track of the shims and put them back the same regardless of amount of backlash. They have worn into a pattern.
