Re: Farmall M / 300 rear tires
Posted by truckerlary on April 29, 2012 at 19:23:47 from (12.19.152.194):
In Reply to: Farmall M / 300 rear tires posted by DaddiosGarage on April 29, 2012 at 19:08:50:
If I remember right the axles on the M are bigger than the 300's. The 300 will be the same as the H axles. As for cutting the heads off the bolts that would be my last resort. I'd put a cheater bar on the breaker bar. These bolts are expensive and the least you will do is break the bolt which will be the same as cutting the head off. You might actually save some. Put penetrating oil down on the threads and let it soak or heat the casting. Larry
