Re: C60 Head Bolts
Posted by wayne in mn on April 29, 2012 at 20:55:10 from (24.179.181.247):
In Reply to: C60 Head Bolts posted by ColeSlaw on April 29, 2012 at 20:18:55:
If the bolt sheared off in the block, an e-z out will likely break off in the block also!
Carefully center drill the broken bolt , enlarging the hole gradually until you can see threads. Use a sharp pointed tool to pick out the old threads and/or use a thread tap to carefully clean out the residue. Vacuum or blow the hole clean. Use anti-sieze on the replacement bolt!!
