NO harm in trying it (worse thing is you fry the genny lol), as I posted below I did it and never had any problems but that dont mean YOUR genny with YOUR VR and YOUR battery etc will do the same mind you NO WARRANTY as it depends on sooooooooo may variables we cant know here!!!!!!!!!!! If youre providing 12 volts it only takes half the current to get the same power mind you ie. A 6 volt genny providing 10 amps = 60 watts of power output, while a 12 volt genny providing only 5 amps = 60 watts (or 120 watts at 10 amps DUH 10 x 12). A genny is more of a current device then it is a voltage device. Its field windings (and armature) can only pass so much current before they could overheat and if you try to pump more through them (which produces more output) then designed for THEY COULD OVERHEAT!!!!! Or if you spin it faster (like smaller pulley) that also increases its output.
THE RIGHT WAY TO DO IT is have a shop convert it and they would install new field coils but if you want to try it as is and simply change to a 12 volt VR it could work (mine did) or it could overcurrent and overheat the fields
YOU HAVE BEEN WARNED and just because mine worked simply by using a 12 volt VR DONT MEAN YOURS WILL it depends on your genny and its Field current ratings and your VR and your battery and RPM SOME WILL WORK OTHERS MAY NOT !!!! No way for anyone to tell sittin here
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
