Colby, since it has been quite some time since the carburetor was rebuilt, do me a favor and give it a quick test before you install it. Hold the carburetor in the upright position, put your mouth on the brass fuel inlet fitting and blow. You should notice only a slight resistance. Now turn the carburetor upside down and blow into the fitting again. If the float and float valve are working correctly, you should NOT be able to blow into that fitting. Needle valves have a tendency to stick, especially after setting for this long. I took some precautions to ensure it would not happen, but it would be better to know BEFORE the frustrations begin.
A good, sharp smack or two with your hand on the side of the carb bowl should cure any problems.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
