Re: experienced builders.... what else could I miss?
Posted by John G. Hasler on April 30, 2012 at 08:10:21 from (174.124.5.28):
In Reply to: Re: experienced builders.... what else could I miss? posted by d282 on April 30, 2012 at 06:13:36:
> If you can I would work it to make sure the
> trans gets good and warm along with the engine
> and then see if you have any leaks.
Look especially closely at the pushrod cover. Each screw is supposed to have a rubber gasket.
