Re: farmall super m, 400 and 460 help needed
Posted by dej(Jed) on April 30, 2012 at 10:49:04 from (141.189.113.1):
In Reply to: farmall super m, 400 and 460 help needed posted by William Whitmore on April 30, 2012 at 10:37:27:
Convert the M to a 1 wire alternator. It is hard to say what is causing the 400 to be stuck. Could be the starter? Make sure it is in neutral before starting. The 460 should prime itself.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
