Re: Farmall 504 gas tractor
Posted by JHubnuts on April 30, 2012 at 10:50:12 from (71.169.144.122):
In Reply to: Re: Farmall 504 gas tractor posted by Dan in Arizona on April 30, 2012 at 07:11:45:
You put the eccentric shaft inside the housing and push it into the bushing as you drive the bushing back into the housing from the outside. Be careful to not mar the inside dia. of the bushing or you'll be replacing that new o-ring you just put on again shortly. And don't drive the bushing in to far or all the linkage wont line up right and you'll have to start over by pushing that bushing into the housing to get it out. Hope this helps
Jason
