Re: Changing 49 Cub to Negative ground 12 volt
Posted by old on April 30, 2012 at 14:15:16 from (209.86.226.18):
In Reply to: Changing 49 Cub to Negative ground 12 volt posted by schultz on April 30, 2012 at 14:07:38:
Your call but for that I would just take a 12 volt battery and mount it some place and then use it and charge it when needed. For something like that it should last longer then you want to drive around. Ya you can switch to 12 volts but it will cost you close to $150 to do that including the battery that is
