Re: Changing 49 Cub to Negative ground 12 volt
Posted by Bob M on April 30, 2012 at 14:27:10 from (74.67.189.51):
In Reply to: Changing 49 Cub to Negative ground 12 volt posted by schultz on April 30, 2012 at 14:07:38:
I agree with Old. Cheapest/quickest solution is to buy a 12 volt battery to run the sprayer when needed. Then simply recharge the battery after each use of the sprayer.
A portable "jump box" will work too - thought they typically have less capacity than a standard car battery.
Or borrow the battery from your car/truck for each spray session. Just make sure not to run the battery down too far to start your vehicle when you are finished spraying(!)
