Re: oil leaking from block on H
Posted by haas on September 23, 2000 at 05:02:15 from (129.37.117.147):
In Reply to: oil leaking from block on H posted by Randall on September 22, 2000 at 18:54:41:
Have you checked the tubing line and connection on the block that goes to the oil pressure gage??
Post A Followup
: Re: Re: oil leaking from block on H
