You would need the adaptor housing like used on a Super M without live hydraulics. M would have different bolt pattern except maybe very latest M. Timing is no problem as the dist drive gear comes right out of the dist reduction drive housing and you can put it in any place that timing lines up. Put engine on tdc, note where rotor is and points should be just breaking. Then put back together same place. This is basic static timing. A 450 should be times full throttle with a light to 25 degrees BTDC if it is factory yet.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
