Posted by pete 23 on April 30, 2012 at 18:39:33 from (74.32.231.176):
In Reply to: h hydraulics posted by chris450 on April 30, 2012 at 11:44:22:
All three ports are pressurized at same time. The rear one side with two is delay drop, (not lift as that requires a separate mechanism). When you push the rod forward to lower an implement, the mechanism inside contacts the rear check ball slightly later but it takes a trained hand to feel that. There are many different way of making it two way, all require adding a separate valve. So called Christmas tree valve was IH's factory way of doing it.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
