Re: experienced builders.... what else could I miss?
Posted by Armand Tatro on April 30, 2012 at 19:29:08 from (98.227.26.140):
In Reply to: experienced builders.... what else could I miss? posted by colby64 on April 29, 2012 at 18:23:55:
Did you rebuild the engine? If so how do you plan to break it in so the rings seat and it does become an oil burner? Refer to your operators manual for breakin oil, hours to run it and at what speeds to run, when to drain the breakin oil and start using normal oil. I know you don't want to work this tractor but it should be worked for at least for at least the first year or your run the risk of the engine sticking and you will not be a happy camper! PLEASE Do NOT LET THAT TRACTOR SIT IDLE!!!!!! USE IT AND WORK IT!!!!!! Armand
