Re: h hydraulics
Posted by mkirsch on May 01, 2012 at 05:31:21 from (64.80.110.74):
In Reply to: h hydraulics posted by chris450 on April 30, 2012 at 11:44:22:
Simple two-way hydraulic conversion:
1. Purchase an OPEN CENTER two-way hydraulic valve.
2. Mount it in a convenient location.
3. Run a hose from the right hydraulic port to the IN on the two-way valve.
4. Run a hose from the OUT on the two-way valve to the hydraulic fill pipe under the gas tank. A tee fitting makes checking and filling the reservoir easier.
5. Run two hoses from the "work" ports on the valve to the rear of the tractor. Install quick-release couplers.
6. Lock the one-way control lever back.
7. Connect a two-way cylinder to the quick-release couplers.
8. Operate the two-way cylinder with the two-way valve.
