Re: coil on a 140 farmall
Posted by rustyfarmall on May 01, 2012 at 06:53:14 from (67.55.162.174):
In Reply to: coil on a 140 farmall posted by longear on May 01, 2012 at 06:49:14:
12 volt would require a ceramic resistor to drop the coil input voltage to 6 volts, or the use of a coil that is internally resisted.
A standard 6 volt ignition on a 12 volt system WITHOUT a resistor WILL get hot.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
