Re: coil on a 140 farmall
Posted by Janicholson on May 01, 2012 at 09:18:57 from (199.17.6.207):
In Reply to: Re: coil on a 140 farmall posted by longear on May 01, 2012 at 06:56:53:
If it has a Key start, there will be a Starter relay on or near the starter. This relay might have 4 terminals. one of the small ones will be labeled "I" this terminal should go to the coil side of the resistor if so equipped. Some have an ignition wire from the key to the coil that is a resistor in and of itself. This would then have that I wire connected to the coil directly. (on the terminal not connected to the points) The resistor in a wire type may not be tha case on your tractor, I do not know) if you measure the resistance of the coil with it disconnected) from smapp terminal to small terminal it should be around 2.5 to 3 ohms if 6volt, or 12v for use with a external resistor. If it is a 12v no resistor required, it will measure about 4 to 5 ohms. If it is a failing coil it will have low resistance. (it could be a 12v coil failing and looking like a 6v in resistance. If you measure the voltage at the coil within 1 minute of turning it on (but not starting it), and the points are closed (normally comes to rest in that position) the voltage will read 8 or less if it has an internal resistor, and about 12.3 or more if it does not. Do not leave the key on for more than 2 minutes with it not running, it will heat the coil even if it is the correct coil. Jim
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
