Re: D.O.T Regs
Posted by Jim Becker on May 01, 2012 at 13:18:01 from (173.74.120.222):
In Reply to: D.O.T Regs posted by Super-H-Mike on April 30, 2012 at 12:25:02:
You needed to make it not too wide. I see two ways:
1) Tip it on it's back. Depending on the drill, may not be an option.
2) Unbolt the hitch. You should be able to take a foot worth of stuff off the front of it.
If you can't accomplish option 2 in 8 hours, you can opt for an overwidth permit.
https://www.dot.ny.gov/nypermits
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
