Re: Is it ecessary to shut off fuel on diesel tank?
Posted by jfrankhash on May 01, 2012 at 17:40:36 from (67.142.173.26):
In Reply to: Is it ecessary to shut off fuel on diesel tank? posted by BerryG on May 01, 2012 at 15:38:04:
You should cut off the gas and let the MD run until it dies, then throw the lever to diesel to seat the valves. No diesel is going to get into the firing chambers unless the injector pump is running, so if that's what you have to do to stop it leaking, I would do it.
I used teflon valve stem packing to keep mine from leaking at the valve.
