Re: International 240 Utility Question
Posted by IH fan on May 02, 2012 at 09:47:34 from (108.236.90.22):
In Reply to: International 240 Utility Question posted by Ericmn20121980 on May 01, 2012 at 11:29:25:
Yeah, filter would be the first thing to check. Next might be any leaks in the suction line to the pump, like a bad o-ring or a crack or hole in the line. Gear pumps do not "self prime" very easily, so any leak can be a problem if it sits a while.
As to what they are worth.... there are probably two things that really matter here... condition and location.
