I just finished up converting my last tractor to 12 volt. Never had a hot start problem but did have -30, no wind chill start problems!
I'm kinda with the other guys on this. If the Mag is the problem you can convert to 24 volt and it isn't going to fix the Mag. It's just like a rope start lawn mower. A mag produces it's own electricity to make spark. When you turn the engine off you are grounding the system out. On a push lawn mower the throttle on the engine contacts a wile and ground is. On a garden tractor with a mag ignition the key switch ground out when turned off and on old tractors like the H the push/pull switch grounds it. Really old system had a spring steel contact mounted on the mag or on one lung engines by the spark plug that you pushed to a contact or the plug to kill it.
Try trouble shooting the system. ID what is wrong and fix that. Throwing parts at something can get real expensive real fast.
You can find many post on here about converting and everyone is for or against it. If you have low compression a conversion may make it start better but you still have low compression. Don't use a conversion as a band aid to cover up another problem.
Today's Featured Article - Listening to Your Tractor - by Curtis Von Fange. Years ago there was a TV show about a talking car. Unless you are from another planet, physically or otherwise, I don’t think our internal combustion buddies will talk and tell us their problems. But, on the other hand, there is a secret language that our mechanical companions readily do speak. It is an interesting form of communication that involves all the senses of the listener. In this series we are going to investigate and learn the basic rudimentary skills of understanding this lingo.
... [Read Article]
Latest Ad:
[More Ads]
