Re: lacky question..how do I get the radio out of a 86 se...
Posted by Brownie 450 on May 03, 2012 at 05:57:06 from (66.43.241.198):
In Reply to: lacky question..how do I get the radio out of a 86 series? posted by Dave from MN on May 02, 2012 at 07:09:52:
Pete must have had all easy "nuts" to remove on the radios he pulled. I've taken several out, & none have come easy.
If your radio doesn't work at all, check the 270 ohm 2-watt resistor on the power output board. They have a high failure rate.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
