Re: Setting valves on Regular
Posted by James Williams on May 03, 2012 at 06:24:22 from (170.215.50.24):
In Reply to: Setting valves on Regular posted by Mark Poss on May 03, 2012 at 03:58:50:
Mark,Ive always set it to TDC and adjusted 1,2,3,5, cylinders than rotate it 360 degrees than adjust 4,6,7,8,.This might sound dumb but Ive never used a gage,I go by sight and feel,I try to run them a little loose.You can recheck them several times after running.If youve had the pushrods out theres a good chance theres some dirt under the pushrods
jimmy
