Re: Setting valves on Regular
Posted by FarrviewWest on May 03, 2012 at 12:53:34 from (165.206.209.230):
In Reply to: Setting valves on Regular posted by Mark Poss on May 03, 2012 at 03:58:50:
This is a simplified version from Janicholson, I just did it on my H and it worked PERFECTLY!
1) Take out the spark plugs.
2) Set the intake valve on cylinder No. 1 (front) when its exhaust valve just starts to open. Turn the engine till the exhaust just starts to begin opening (moves) then adjust the intake valve.
3) Set the exhaust when the intake just closes. Rotate more until the intake just closes (just stops moving after having been open) and adjust the exhaust.
Treat every cylinder (pair of valves) the same way, remembering they switch places between cylinders.
The order in a Farmall H is: (front to back EI - IE - EI - IE )
