Re: Farmall Super A clutch won't disengage
Posted by Janicholson on May 03, 2012 at 18:09:58 from (96.24.99.126):
In Reply to: Farmall Super A clutch won't disengage posted by Barstart on May 03, 2012 at 16:35:39:
WOrn splines in the clutch shaft will do what you describe. The new clutch gets stuck on the worn splines and continues to push against the FW. In most cases, it takes resplitting, to get at the splines. Either replace the shaft, or use a dremmel to remove the binding edge, or shorten the new hub some to comply with the worn section. Jim.
