Re: Please explain to me.......
Posted by gbs on May 03, 2012 at 19:20:21 from (71.51.250.84):
In Reply to: Please explain to me....... posted by oldtanker on May 03, 2012 at 08:46:38:
i believe someone's theories have gotten crossed up, if what is being explained is correct how did the old timers leave them (parked on starter as they called it)then let it roll down the hill pop the clutch to start it ,the principle behind the impulse coupling is to snap the magnets in the magneto past the windings fast enough to create at spark at low speed,once the speed range of the impulse coupling is exceeded the magnets are spinning fast enough to produce enough current to fire the coil,if you want to test this turn the flywheel of a small engine in a slow continuous motion passing the magnets under the coil no spark,then rock it past in a snapping motion it will fire.
