Re: Water Temperature Gauge
Posted by redhead on September 23, 2000 at 16:07:56 from (63.27.255.143):
In Reply to: Water Temperature Gauge posted by Larry on September 23, 2000 at 15:55:05:
Did you put a new capillary tube on with the new gauge. Some gauges come with a new tube and some don't. The tube is the small pipe between the gauge and the block/head. Also, try removing the adapter at the block/head and see if there is some crud built up under it and not allowing coolant to contact the tube. Good luck and keep us posted.
Post A Followup
: Re: Re: Water Temperature Gauge
