Re: 460 Utility!
Posted by Philt on May 04, 2012 at 01:23:58 from (166.147.96.93):
In Reply to: 460 Utility! posted by DeltaRed on May 03, 2012 at 20:57:43:
Just had to replace the pump on my 460 this spring (not cheap) but cheaper than buying a new loader tractor. The only way to know if it's a bad pump is to do a pressure/volume check. On my tractor there is a plug on the right side under the brake area to check fluid level and a plate by the gear shift lever with 3 bolts to fill it but mine is a row crop not a utility. Best bet is to order the manual.
